TAC Tech => Interior => Topic started by: roadking77 on September 29, 2025, 05:45:16 AM
Title: Console Styles
Post by: roadking77 on September 29, 2025, 05:45:16 AM
Is the console for an '81 car different than that for an earlier car?
Title: Re: Console Styles
Post by: ryeguy2006a on September 29, 2025, 05:52:51 AM
Not sure if it's like that for all 81 models, but the ones that had the computer controlled carb had no provisions for the console because the computer sat behind it.
Post by: Maxthe222 on September 29, 2025, 11:40:17 PM
Yes, all 1981 Firebird consoles were completely different as they had a blocked off map pocket area with a side door flap as they had the Computer Command Control module inside them. Canadian cars may have received the standard map pocket console, as they didn't require the CCC.
1980 consoles were slightly different, where they weren't molded closed, but had different brackets that were embedded into the walls for a flat block off plate for the turbo light switch and bezel.
Post by: N PRGRES on September 30, 2025, 06:04:26 AM
Here is a photo from my 81
Post by: roadking77 on October 01, 2025, 06:48:58 AM
Thats a good pic. The one that I am questioning about does not have the decorative recess at the very bottom. I was not sure if it was for a camaro.
Post by: nUcLeArEnVoY on October 14, 2025, 08:49:53 AM
I researched that as well, and I've come to the conclusion that in terms of ORIGINAL parts (aka, the repros are incorrect), the automatic consoles have that decorative recess while the manual trans consoles have it flush/smooth all along the console like how the repros are. Enough searching for originals on eBay is how I came to this conclusion.
Post by: N PRGRES on October 14, 2025, 11:49:26 AM
I don't know what you mean
