Hello looking for input on installing bellcrank (z-bar} bracket for a Auto to Manual swap. Car was automatic, but looks like factory holes were in the frame for whatever transmission the car would get.
In mounting the bellcrank bracket on the left frame outside, I plan to use 5/16 (8MM) self-taping screws. Questions is should I tap threads into the hold first, or can I just use an impact wrench and drive the sefl-tapping screws in. The pre-drilled holes have never been used and the hole, while drilled completely through, appears to only have punctured the frame and not drilled through as to make a clean hole, if that makes sense.
Also for the opposite side of lelft rail frame, will be installing the bracket for the neutural/reverse rod. Again there are pre-drilled holes, but the three on the inside of the frame are nice clean holes, whereas the three holes on the outside are not as clean drilled through. So I'm thinking I need to tap the inside frame for the bracket, and use a bolt instead of self-tapping screws here.
Thank you
