For all Firebird - Trans Am Enthusiasts
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Electrical
Battery Cable
« previous
next »
Pages: [
1
Author
Topic: Battery Cable (Read 7397 times)
Battery Cable
on:
July 11, 2024, 09:12:14 AM »
So if you don't have the wire tube on the front of your 400 for the positive battery cable, wo you run it? I have the tube but due to some modifications I might have to remove it, so Iam trying to figure out the best route for the battery cable.
Re: Battery Cable
Reply #1 on:
July 11, 2024, 01:02:03 PM »
Could you modify the tube to accommodate? Or a spare?
Re: Battery Cable
Reply #2 on:
July 11, 2024, 03:19:54 PM »
I dont have the tube on my 77, I think it just runs basically in the same area. I would have to look to see exactly where it goes.
Re: Battery Cable
Reply #3 on:
July 11, 2024, 04:51:23 PM »
Quote from: b_hill_86 on July 11, 2024, 01:02:03 PM
Personally, I would not run it without unless you can keep the wires far from the exhaust manifold and exhaust port of the head. I suppose it wouldn't hurt to have a temperature reading of the tube compared to the exhaust manifold and exhaust port to see how much cooler the tube actually is. I can't see Pontiac or GM spending money on something that was not necessary. The positive battery cable is always hot and is not fused, while the other wire (trigger for the solenoid) is only hot when the key is in the start position and would be protected by the fusible link coming from the alternator.
Even my original 301 came with this tube, I had to slightly bend the bracket to make it work on my new engine.
IMG_3759
by
Lawrence Alexander
, on Flickr
Re: Battery Cable
Reply #4 on:
July 17, 2024, 07:36:54 AM »
I got it all situated and was able to keep the tube. Thanks Guys
Re: Battery Cable
Reply #4 on:
Pages: [
1
« previous
next »
TAC Tech
Electrical
Battery Cable
