Author Topic: Madaguy 1955 Nomad Build  (Read 365020 times)
Re: Madaguy 1955 Nomad Build
« Reply #320 on: March 12, 2025, 06:40:31 AM »
20250228_145340 by Kerry Grubb, on Flickr
Springs came without a box, I bought 4 tires online for my truck. This is how they arrived. Fed Ex driver told me he had no idea where the 4th one was but that it should show up in a day or two :shock:
It came the next day.
« Reply #321 on: March 12, 2025, 02:12:05 PM »
I've had tires shipped to me like that too. I guess it's more efficient that way haha.
« Reply #322 on: March 19, 2025, 09:40:51 AM »
It's been a while since I've been back into the swing of things and got some work done to the car. I've been collecting parts, buying/selling, house projects and etc, but now I want to get back to the car and ready for some warm weather cruising. There are several things with the front end that I want to address, but first up was the stance. I installed the CPP C5 2" Drop springs and tubular control arms last fall, but after I got them installed it seemed to be no change in the stance. I think with the isolator cups in the bottom of the lower control arms it acted as a spring spacer to offset the gain from the 2" drop spindles. I opted to cut one coil off of the springs to hopefully stiffen the front end slightly and get a lower stance.
Initial measurement was 28" left and right.
Got it back together and the drop was about 1.5"
Before:
After:
It's hard to say how much it will change until I get it outside, but it is noticeably lower.
Next up was getting my original inner fenders installed. I didn't get any pictures, but I repaired the lip and some pin holes on the lower sections. Got them prepped and repainted with SEM Trim Black to match the firewall.
Started with some disassembly
Only a handful of hardware held on the front grill. We'll be changing that!
After struggling a bit to get it installed, I needed to remove the lower bolt down by the rocker to allow the fender to swing out. That gave me enough room to get the upper side into place. After wrestling with the fender a bit, I finally got a few screws in place. I also installed some original fender brackets I picked up that were powder coated and came with some original zinc coated hardware.
Took some time to clean up the core support and repaint, then installed some new aftermarket filler panels that I picked up several months ago. I painted them flat black, but it doesn't quite match the sheen of the Trim Black which I ran out of. I'll touch it up though before I button everything back up once I get a new can.
I notched the passenger's side where the transmission cooler lines go. Used a hole saw to get the radius and my tin snips to get the straight lines.
I ran out of the package of screws that I bought for this project so it's not final, but so far it looks way better than it did before. Inner fenders and new filler panels make a huge difference.
The I turned my attention to the front lower valance panel. I didn't pay much attention before, but the back is in pretty poor shape. I'm going to attempt to repair it, but may just pick up a new one when I'm at Spring Carlisle next month.
That's where I left the car a few days ago, but much more work will be done to clean up the engine bay. I was also able to snag some more key parts that will be very helpful with the next stage of my build. First up is a Mighty Mouse catch can. It's got the fittings for boost already installed, just need to buy or make a bracket for it to be installed.
Also my Quick Performance 9" housing and axles arrived! I haven't gotten a chance to take them out of the box, but they are really solid pieces and look very well built. 1/4" axle tubes, internal gussets, HD leaf pads, 35 spline axles and GM Flush mount ends. With those ends I'll be able to use my favorite rear disk brakes off of 98-02 Fbody's.
I still need to buy an assembled third member, new rear rotors, NiCopp line and other misc. things before I can assemble/paint the rear and get it installed. Then even before I could run the new rear, I'll need to get it installed and measure for a new heavy duty driveshaft. In the meantime, I plan to get the rear springs swapped out soon so that I can take the car to get a front end alignment and still keep the car functional. I also want to add my flex fuel sensor, swap to the Dorman LS2 intake, add the Vaporworx module and get it wired up. I haven't decided if I'll swap out my fuel pump now, or wait until the car is boosted to swap to the CTS-V pump.
Lots of moving parts, but I'll get them all figured out.
« Reply #323 on: March 19, 2025, 01:35:22 PM »
Lots of cool stuff going on. I really enjoy seeing what you are doing with this car.
« Reply #324 on: March 20, 2025, 02:52:52 AM »
Very exciting stuff!!!  What’s the Mighty Mouse Catch Can do?
« Reply #325 on: March 20, 2025, 05:59:03 AM »
I wondered the same thing.
« Reply #326 on: March 20, 2025, 09:27:36 AM »
Ryan: the car looks great. I always enjoy your updates.
Google is your friend.
https://www.mightymousesolutions.com/catch-cans
« Reply #327 on: March 20, 2025, 08:06:10 PM »
Thanks guys. The catch can is part of the pcv system and runs the crankcase air that normally travels to the intake, through the catch can instead. Inside the air travels through a wire mesh that allows the oil and dirty air to deposit contaminates and store them in the can rather than back into the intake. LS motors are pretty notorious for using oil and collecting in the intakes. If you see some posts from about 6 months ago, my intake was full of oil. I swapped to a valley cover with pcv like the LS3 motors have, but they will still pull oil even with that. Should help the motor run cleaner.
« Reply #328 on: March 21, 2025, 06:10:01 AM »
Thanks, that makes sense, it looks like these cans are even more important on a boosted motor
« Reply #329 on: March 31, 2025, 09:48:14 AM »
Another weekend and some more progress. I've been working a little bit at a time to get closer to installing the Dorman LS2 intake, and it got to the point where I was ready to pull my TBSS intake and do the first test fit. First up was to swap out the stock valley cover bolts for the low profile cap bolts to clear since the intake sits a little bit lower.
First test fit was happy at first because it looks way better than the truck intake, but soon was slightly disappointed because the water pump won't work with the throttlebody. I'm too far down the path now, so I have to move forward with my intake swap. I found a few good deal on eBay for a low mileage C6 water pump and balancer. More research was needed on what the best plan would be for the alternator bracket. I eventually wanted to swap to the Corvette accessories to gain 1.5" in front of the engine for turbo stuff, but this situation sort of forced my hand.
Since I need to swap the balancer and swap water pumps, it was much easier to just pull the radiator to get that out of the way. While I had that off, I might as well fix the driver's side frame horn! It was bent in and the top was twisted in as well. I could have used a porta-power I didn't feel like buying one for this project, so I used what I had. My press jack, my BFH, slide hammer, welder and leverage when I could.
Don't try this at home. It didn't work well at all and was quite sketchy.
Before:
After:
I wasn't striving for perfection, but rather a frame that measured straight and within specs for width. I tried to get it back as close as I reasonably could to the original look. I think it turned out pretty good considering the tools I had available.
Another little unexpected surprise was picking up a set of cool late 90's gauges from Custom Rod Gauges. The guy selling them said that all the gauges but the speedometer worked. I took a chance since he was selling them so cheap. The overall reviews for the company seem to be poor customer service, but a quality product. The gauges are all VDO internals.
After pulling off the back cover, I noticed that one of the leads had the solder broke off. I connected it to the right connection and the gauge fired right up! WIN. They came with all the sensors and just overall needs a little TLC. I haven't fully decided if I'm going to run them because I really do love the original gauges. But good to know that they all work.
I also found some electrical tape on the speed sensor wiring that came with it. Each lead was crudely wrapped with electrical tape. I wonder if that had any reason to do with why the Speedo wasn't working??
I placed my order for the Speedway 9" assembled third member with 3.25 gears and 35 spline Helical Posi unit. While I was on there, I also saw something pop up for a sway bar in the garage sale section. Comments said it appeared to be installed, but returned for one reason or another. It had a decent discount so I grabbed it too. The hardware was brand new so it had never been installed, but I think some paint was scuffed off in shipment. That's fine with me. Easy touch up. That's another reason why I needed to straighten out the frame because where the sway bar mounts to the frame didn't sit flat.
I ordered a bunch of parts to finish the install for my 9", catch can, fuel pump controller and other misc. things. Once it all gets here, I'll be able to button everything up fairly quickly and get some more road miles on the car this season. The weather rapidly changed and we're in full on spring here in central Virginia. Can't wait to get it back on the road!
« Reply #330 on: April 02, 2025, 05:56:05 AM »
Good update :grin:
« Reply #331 on: April 02, 2025, 08:08:08 AM »
That frame straightening scared me but good job!
« Reply #332 on: April 03, 2025, 06:57:33 AM »
Made quite a bit of progress over the last several days. With the frame horn fixed, I was able to get the sway bar installed. The bushings sat nice and flat on the bottom of the frame rails, so that made me happy.
My C6 balancer came in. Was a new takeoff piece from a crate motor. I have the puller, flywheel locking tool and installation tools already so this was a pretty quick swap. Pull the truck balancer and install the C6 unit.
After researching a bunch of different options for the alternator/PS brackets, I decided on the unit made by Holley that replicates the stock C6 bracket. The big difference is the alternator spacing, which allows you to use the more common truck units. Since I already had a good alternator, it made sense to pay a little more for this one so I didn't also need to buy a new alternator. And it will likely be easier/cheaper to replace if this one fails at some point. I ordered it through Summit, and while I placed the order I also grabbed the rest of the fittings to install my Mighty Mouse catch can.
The Holley bracket is a really nicely cast piece. It's incredibly smooth out of the box and looks to be very well made.
I had a mix match of parts, and decided to paint all of the brackets and accessories satan black. I've seen a lot of motors with that combo and I wanted to clean up the looks of the engine bay while I'm in this deep.
For some reason they were still tacky the next day so I set them out in the sun for about 4 hours to cure.
Once they were all painted up, it was finally time to see how they looked on my motor with the new intake. Very pleased with how they turned out. I've always liked the way the alternators looked painted all black.
Then another issue popped up. I went to test fit a belt I have and quickly realized that the tensioner is very close to the throttlebody plug. After researching many different options, I realized that it must be because this intake was designed to work with LS1 accessories. I tried flipping the TB, but the motor hits the water pump.
After a few degrees of rotation it contacted the connector, so that will not work.
After thinking on it a while, I got the idea to try and rotate the tensioner on the lower mount. BINGO!
It rotated it enough to allow for full articulation of the tensioner. I cut the boss off of an old truck tensioner that I had laying around and will weld it to the original tensioner so that it won't move around. The good news is the tensioner is pulling towards the stud rather than away from it, so there will always be a force in the right direction.
I used an old truck water pump I had to bolt it all in place so that I could TIG weld it into place. I'm a beginner, but the weld will definitely hold it in place. Then I milled the reverse side flat so allow the bolt head to sit flush.
Touched up the paint, and I think it looks great!
Before the final installation of the accessories, I drilled and tapped the water pump for the steam port lines. When I first put the engine together I realized that I had some block off plates in the front, so it wasn't ever fully bleeding the air from the system. This will be a good piece of mind update.
In order to install the LS3 style 1000cc injectors into this intake, I had to make some new brackets for the fuel rails I bought. They are generic Amazon rails, but do look to be well built. I used some aluminum angle bulk from Lowe's and it ended up being the perfect height for these injectors. Just trimmed them down and rounded off the edges. Then painted.
Once the brackets dried, I installed them onto the fuel rails and installed on the car. I'm really happy with how this update turned out. I figured while I'm swapping intakes I might as well get the new injectors installed so that I'll be that much closer when I add the turbo. It will take a bit of time to get my new base VE table updated, but I think the existing table will give me a great base to start from.
I also received my 9" third member from Speedway a few days ago. It was packaged up really well, and I only pulled the cover off to take a picture but for now it's staying in the case for safe keeping. It's a Nodular Iron third member with 35 spline Helical Posi differential and 3.25 gears. I'm really excited about putting together the rear end, but for now I want to focus on getting the engine bay back together. I have a complete LS1 rear disk brake setup for it as well. Just needs to be cleaned up and painted since the backing plates need to be installed before the bearings can be installed. I opted for the GM bolt pattern flush mount ends which are designed to work with these brakes.
Over the next week or so I'm hoping to get the flex fuel sensor mounted and installed, reinstall the battery and re-route some cables, loom all the wires in the engine bay, install the fuel pump controller (requires installing 8 ga wire to the rear of the car and tapping into the MAP sensor), and modifying the CTS-V fuel pump assembly so that I can swap that into my tank. I was going to just run the car as is, but if I do that, I'll end up needing to modify my VE table twice. With the fuel pump controller it will ramp up based on boost pressure and because of this, I like to run the pumps at a starting pressure of 43psi. Going from a base pressure of 58psi to 43psi will change the fueling required in my VE Table.
« Reply #333 on: April 03, 2025, 12:28:37 PM »
Ryan, every time I read your updates all I can think about is how many balls you have in the air at one time and how far this car has come. I will be curious to hear your critique on how the car handles after the suspension upgrades. That new pumpkin is almost too pretty to be hidden under your car! Once you do the power upgrades you’ll be glad to have such a stout transmission and differential. This thing will be a monster when finished and still have great street manners for cruising with a reliable EFI LS.
I am out of town visiting friends, kind of a crummy weather day, so I had a chance to reread all your posts from the beginning. Amazing!
« Reply #334 on: April 04, 2025, 07:16:50 AM »
I appreciate the compliments! I'm usually thinking several steps ahead when I'm building cars, so I like to plan ahead for the projects I'm doing. I don't get that much garage time, so I like to maximize it when I'm out there. Nothing worse than when I'm right in the middle of the project and am forced to stop because I need a part.
I've done the same a few times and read the build from the beginning. It really has come a long way and I'm really proud of how it's turned out so far. Still a ways to go and it will likely always be evolving, but it will be nice to just cruise it for a while this summer. I need to cool it on buying new parts for a while. Although in reality once the rear is under the car and the new fuel pump/controller are installed I won't need that many more parts to add the turbo haha.
« Reply #335 on: April 04, 2025, 08:41:53 AM »
Your updates make me feel like a slacker, that a good thing, it gets me motivated!
« Reply #336 on: April 14, 2025, 07:48:01 AM »
We took advantage of the kids having off last week for spring break, and took a long weekend trip last weekend in Pigeon Forge. Was great to see the mountains and relax in a cool cabin. I kept seeing all these cool hot rods just parked on the strip and wondered why. Then I realized that this last weekend was the Rod Run there. Missed it by a week, but still got to see some really cool cars along the way.
Saw this really clean 1956 Belair, then noticed this really cool detail! I'm borrowing that for my car because I need to replace the filler panel as it's heavily rusted.
Back to work on the car. Once I got the tensioner figured out, I needed a new belt to match. This ended up being the length I needed. I also forgot to mention that with the Holley bracket, it also has provisions for Power Steering, but I'm not using that right now. But what will be nice is that all I'll need to do is add the pump and hoses when the time comes.
Next up was figuring out how I wanted to mount the flex fuel sensor. After a lot of thinking, I decided to build a bracket off of my booster. I remembered that the original brackets that I bought for the booster came with two of the same side, so Summit sent me the correct ones. I trimmed off the excess, bent it to a 45* angle, then tapped for the right hardware. Turned out great with minimal fabrication, WIN!
On every LS swap that I've done, I've used a roll of Nylon fuel lines and love how easy they are to work with. I've used the caulk gun method many times and is quite easy. For those that haven't seen it, you use a brake flare tool to hold the line, then a two post caulk gun and use it to press the fitting in. Make sure to measure the depth of the barbed side and then clamp down tight, but not all the way. It will distort if you clamp too hard.
Position it like this, and use steady pressure to get it started and ensure it's straight. Once you can tell it's going in straight, I just use a few quick presses until the line is flush with the end of the fitting.
Here you can see the fitting is flush with the line. I bought this piece of repair line from Autozone that had a 90* fitting and just pressed a straight fuel fitting that I had in place. You can also see the flex fuel sensor mounted in place and all my lines are now complete. I had to heat and bent the lines around to give some slack for motor movement and to avoid hitting the firewall. Really happy with how it turned out.
I came across this really cool harness from Current Performance Wiring that is a plug and play flex fuel along with a 2 pin alternator plug. What's cool about this harness is it has a PWM generator built in to give the two wire alternator the right signal to charge up to 14.5v. Now that I have the harness I just need to add the flex fuel to my tune and can test out a tank of e85!
My lower radiator hose worked the same, but needed to be trimmed a bit to avoid hitting the frame, but the upper hose was way different since it came out on the driver's side rather than the passenger. After playing around, I realized I just needed a hose that came out at an angle to avoid the air intake. I went back to Autozone to browse the different hoses and found one that worked. I couldn't find one that had the jog I needed, but was able to cut the water neck off of an old truck water pump and that curve worked just like I wanted.
I also ordered some grommets for the firewall to get things sealed up.
I need to install the speedometer grommet too and the wiper motor grommet is already installed. I also was looking at the firewall and everything is cleaning up really nicely and the wiper motor stuck out. I ended up spraying it in Satan black and it looks great. Not original, but disappears now on the firewall.
This project has certainly snowballed, but I'm getting closer to the end. I've been taking my time to clean up the wiring and loom it as I am going. Which means I've been having to re-route wiring and I also swapped out the battery cables I had with some that I acquired from a 2016 F150. The terminal clamps are really nice and the cables are high quality. I'm not done yet, but it's all starting to fall back into place. I have the coils off to clean up, then I'll reinstall. I'm debating on painting the valve covers a flat red, or even wrinkle red finish. Still up in the air, but I think it would give the engine bay a pop of color.
While the car is "down" and I'm in the wiring mindset, I'm also swapping to the Vaporworx module to control my fueling. I went back and forth on where to locate the module, and finally tried under the rear seat. I still have access to the set screw for adjusting the fuel pressure, but it's out of the way. I want to add a cover to it so that the pins cannot short out if a screwdriver or something fell down and shorted it. I started to run the main 8 gauge wires from the battery, and the MAP signal wires but haven't finished.
Once the wiring for the module is complete, I need to work on getting the fuel pump assembly modified to work with my fuel tank. I'll need to extend the wiring, extend the support rods and ordered a new longer corrugated hose. I also need the correct -6AN fittings to add the Fuel Pressure sensor from the fuel module. Swapping fuel pumps also means that unfortunately I'll need to drop my fuel tank which I believe is almost full. Although it will give me an opportunity to test the fuel sender as I think it may be going bad. More to come, but hopefully the car will be back on the ground soon.
« Reply #337 on: April 14, 2025, 11:47:06 AM »
darn that's sexy!
« Reply #338 on: April 15, 2025, 04:27:07 AM »
I'm pretty sure it was your 76TA build that turned me on to the plastic fuel line. My LS TA swap used like a whole roll of that stuff. Seems to be working fine. I figured, if the factory could use it on cars why can't I. Keep at it, you'll soon be back on the road!
« Reply #339 on: April 15, 2025, 06:04:41 AM »
I enjoy your updates. I always learn something from them.
« Reply #340 on: April 25, 2025, 07:18:29 AM »
This will be sort of a scattered post since I have been working on multiple projects all at the same time. The Spring Carlisle swap meet is this weekend and I had been waiting until then to pickup some parts with one of them being a rust free original lower filler panel. To my surprise, my father in law shipped one to me that he bought on eBay! Thanks Bern! It's in fantastic shape and even has the factory undercoating, which is pretty amazing. It has a few dents in it which is expected given it's age, and since I don't want to do body work on it I have a plan.
It fits really nicely on the body.
Before I could do anything with that I wanted to continue working on my wiring and my new fuel pump setup. I decided to just use the fuel pump that came with the Vaporworx controller I bought a few weeks ago. I wanted to pull the assembly apart to make sure there wasn't any debris hiding. I was in a bit of a hurry and my caveman self used too much leverage and broke the venturi fitting on the fuel pump. It's not something that can be easily fixed, but after reaching out to Carl at Vaporworx and making some posts on forums and FB, I found a guy who had some leftover parts from upgrading a CTS-V pump and sold them to me for very cheap.
Thanks Bill from FB! Bonus is that he had an extra fuel bucket and support rods. I've been trying to think how I was going to extend the rods to raise the fuel pump assembly by about 4.5", and this solves that problem. I can cut the ones I have, as well as the ones he sold and then the factory clips will work as they should.
I also bought some "made in the USA" Moog inner and outer tie rods from a member of Tri-Five a few months ago and now I'm ready to swap them out. They were bare steel so I just sprayed some flat black paint on them. I bought some slick UMI adjusters a while back too that should make adjustments easier.
I pulled the steering column out so that I could install the firewall seal that I should have done from the beginning. While I had it out, I swapped out the stock ignition switch with an aftermarket unit because the lock cylinder kept falling out. I also fixed the dimmer switch for the gauges and tidied up some wiring while I was in there. I also need to shim the steering box so it is centered. All good things that need to be done, but aren't that exciting.
I also unboxed my Quick Performance 9" rear and started to prep it for welding on the tabs for brake hoses. I want to make sure that they aren't in the way of installing U-bolts, suspension or anything else. I'll tack weld the tabs then install it in car to make sure nothing will interfere.
Here's what I started with, and the backing plates after a little TLC.
I bought new boots from Dorman for the ebake lever as well. For those that are curious they are the stock brake assemblies off of all 98-02 Camaros and Firebirds which are often referred to as "LS1 Rear Brakes". Fantastic brake setup; 12" rotors, PBR Calipers, internal ebrake assembly, and use the standard GM backing plate bolt pattern used for decades. When I had QP build my rear I had them use the Moser GM Flush mount housing ends so that I could use these brakes specifically. I also have a pair of C5 brake calipers that are a direct replacement for the Camaro units, but these are supposed to have a better casting. I picked them up on eBay for super cheap and bonus was they came with Hawk brake pads that look barely used.
I also don't remember where I bought it, but I had a single brand new dust shield kicking around in my garage that I was able to use instead of the crusty one. The other side cleaned up pretty nicely so that will get reused too.
Back to the wiring, I added a 70 amp breaker to inline with my C7 fan for added protection.
After wrapping up a few other items, I was finally able to get my new filler panel painted fitted and installed. After that, I reinstalled the radiator filler panels, grill and front bumper. With all of the changes in the front end, I also had to re-align the hood which has never fit better! Very pleased with this when I step back now. Love it or hate it, it's very unique and I love it!
I also was able to step back and check out my new engine bay. It took a lot of time and energy to route all of the wiring and wrap it all up. I'm very happy with how it all turned out. I still need to power wash all of the pollen off everything and loom up the headlight and turn signal wiring, but after that I'm calling it done. At least until I buy some turbo parts...
Hoping to get tabs welded to the rear, paint and swap it out for the stock rear. I also need to wrap up the Vaporworx module install, modify fuel pump, and swap that out with the Gen 5 Camaro unit I have in there now. I'm really starting to see the light at the end of the tunnel, and cannot wait to get back behind the wheel. Hopefully in the next few weeks.
« Reply #341 on: April 25, 2025, 06:41:32 PM »
You do good work!
« Reply #342 on: April 26, 2025, 07:54:53 AM »
Coming along great!
« Reply #343 on: April 27, 2025, 07:18:47 AM »
Looks fantastic!!!!!
« Reply #344 on: April 28, 2025, 06:52:37 AM »
Thanks guys!
« Reply #345 on: May 16, 2025, 12:12:26 PM »
It's been a little bit since I've had an update on this project. Between work, building a porch and life it has been hard to get anything done on the 55. I've done a few things here and there, but have enough for an update. Once I got the front end back together, I wanted to start on swapping out the tie rods since they were quite worn.
Once I had the complete assembly out it was time to break them down. Looks like someone removed the bushing with a torch then just reinstalled a new bushing. Not comfortable with that, so I ordered a new one from CPP.
I have new Moog bushings, but since the new drag link will have a new one already installed I'll just put a new Moog in the idler arm.
While that was all disassembled, I removed the steering column so that I could install the column firewall boot and seal. I could have cut it, but I decided it wouldn't take that long to pull the column and so it seals up better. Well that lead to me also shimming the steering shaft so that it came through straight and not off to one side. Before and after. I think it took 3/32 of shims to the lowest bolt to straighten out. Much happier.
I also cleaned up all the hardware for the LS1 rear brakes so they are all ready to install when the time comes.
Huge thanks to plasticman on the Trifive site for sending me this shock bar. Hoping to get that installed when I pull the stock rear to replace with the 9".
I've been trying to track down the 55 Nomad trim pretty much since I bought the car, and finally found someone who would sell me a set for a reasonable price. They are reproduction cast aluminum pieces that are uncoated. They fit really nicely too. He sold me both eyebrows and the door trim, so I still need to track down the fender trim but I'm stoked to find what I have. I couldn't wait and got the eyebrows test fit immediately. Can't wait to install them for good!
And wouldn't you know it, when it rains it pours. I hardly ever check Craigslist anymore, but happened to open it and a short listing popped up and mentioned Nomad parts. I clicked on it and saw among a pile of parts a pair of original eyebrows! I reached out and the lady and after communicating for about a week, we met up last weekend and I bought all of the parts from her. Ended up being probably a hundred parts with many Nomad parts, 55 Belair pieces and many NOS parts. It ended up being her father's entire collection of parts that she inherited when he passed away in 2016. They had been in dry storage all this time.
Borderline holy grail!
Really cool license plate boarder. Definitely running that!
Can someone help identify what these parts are? I've never seen anything like these before?
Then I recently welded the tabs on the rear for the rear disk brake hoses, and painted it. First etch primer, then some medium and heavy coats of Satan Black.
Hoping to get the new springs installed this weekend and the 9" test fit so that I can measure for a new driveshaft. I'm 99% sure that I'll need a new one and want to get that ordered so that I can get this car back on the road. I'm still debating on pulling the gas tank to install the CTS-V modified unit so that it's all ready for when I add the turbo. I'll probably do that anyway since I'll want to remove the fuel tank when I weld in the shock bar. Still up in the air though since I may just get the new rear installed and run it the rest of the year. I really want to drive the car again. I forget that I lowered the front end and installed a sway bar as well. It should be a completely different handling car once I have a proper alignment.
« Reply #346 on: May 20, 2025, 12:52:46 PM »
I'm really regretting tearing the car down earlier this year AND letting the project snowball a bit. But never the less, here we are. I'm trying to make a big push to get the car back together and on the road. Picking up where I left off, I needed to get the stock rear out of the way. I didn't want to disconnect the rear brake lines just yet, since I know the new rear will be in and out a few times test fitting so I removed a few brackets and slid it under the car still intact.
Once I removed the stock rear along with the leaf springs, I put the third member into the QP rear housing so that I could test fit everything. It looks great in there, but I still need to paint since it's raw cast iron.
Pretty big win was the driveshaft that is in there now will work with the new rear! That will be something that I can upgrade when I add boost, but for now is a nice cost savings! And yes, the rear has the full weight on it with me bouncing it a few times.
The bad news was that when I test fit with the new drop springs, the passenger side was contacting the spring hanger near the shackle just like it was with the old springs. I thought that it was because the old springs were flattened, but as I dug deeper and started measuring I found the culprit. Somewhere along the way the front spring hanger was bent up a good bit. So much that it even tore the hanger slightly!
After comparing to the driver's side and taking some measurements the outer hole was what moved. I was able to bent it back with many precision hits from my BFH. I kept measuring to have it match the driver's side. Once I got it back into place, I drilled the end of where it was torn, cranked my welder voltage up and laid several passes of hot weld. I'm confident that it will stay in place now. I test fit the new spring again under full weight and it had plenty of clearance around the shackle, just the same as the driver's side. Crisis averted.
While I had the new rear in place, I also took the opportunity to test fit the new shock bar. Thank you Plasticman!! It ended up being the shorter bar I think for the one piece frame. It ended up being half an inch short, so I put my thinking cap on and decided to make two 1/4" plates and weld those to the frame, then tap all the way through them for a really solid removable mount. Very happy I was able to make it work. Welds could have been better if I wasn't welding out of position under the car. I got solid penetration though so they won't come off, just not pretty.
I also forgot that you have to remove the rear end to get to the fuel tank and since I was having an issue with the fuel sender reading incorrectly and wanting to swap fuel pumps it was the right time to do it now. I pulled the tank and took some measurements so that I could first modify the CTS-V fuel pump assembly to fit into my modified fuel tank. That meant modifying the assembly to add about 6" of height. The guy that sold me the new venturi setup also had some other spare parts including two rods. That was perfect, because now all I had to do was trim a bit off one end and then weld them together. I determined the height I needed, then subtracted 1/2" so that it wasn't bottomed out when I compressed the assembly. Cleaned the ends with acetone and tig welded back together.
Once that was done, I swapped the fuel pumps to the new venturi assembly that I didn't break and added the extended fuel hose.
The pump I bought came with upgraded dual AEM 340 lph pumps. Will provide more than enough fuel under boost.
It was also not necessary, but I bought them a while ago so thought I'd swap them out. Most 90* fittings have a hard transition inside where they are drilled from both sides. I swapped that out for a full flow fitting that has a smooth transition inside. No idea what that does for performance if any, but makes me feel better there is less restriction I guess.
Then I extended the wiring and added a fitting to add the fuel pressure sensor for the Vaporworx module. Ready to test and install.
Last thing was to swap the sender out for a new piece I bought from Tanks Inc. The sender was an original piece so I assumed it was failing, but when I pulled the sender the float was full of gas! Must have a pin hole in it somewhere. Oh well, I opted to install the new one since I had it. Hurt a little to cut up a perfectly good sender, but I don't need the carb style pickup. I had to bend the sender over slightly and readjust the float arm so that it would clear the fuel pump assembly.
Lastly, I know the common deal is to seal using a cork gasket, but I used a liberal amount of Seal All everywhere when I installed this with the rubber gasket. I even put a dab on the screws, so I'm confident that it will seal like it did before. That also used a rubber gasket with the stock sender.
The plan now is to get the fuel pump installed and finish the Vaporworx installation so that I can verify fuel pressure and functionality. Assuming there are no leaks I also want to start the engine again with all the new mods. I changed a bunch of settings on the tune to add flex fuel, new 1K CC injectors, new intake manifold/Throttlebody and will lower the fuel pressure to 43 psi since I'll have a boost referenced pump now. With all that I'm expecting the tune to be way off. But my hope is that it can at least get the engine to idle. Then I'll feel confident that the fuel system is good to install for good. Then with the fuel tank installed I can start bolting everything back together. I'm very excited to get the new rear end installed and see what the stance is with the drop springs and cut front coils. Lots of exciting stuff hopefully with the next update!
« Reply #347 on: May 21, 2025, 06:20:47 AM »
Looks great!
« Reply #348 on: May 27, 2025, 11:50:27 AM »
Continuing from where I left off, I put together the fuel pump wiring based on advice from Carl at Vaporworx. 8 GA wire from the battery, then about 6" from the pigtail, I split each into two 12 GA wires that feed the pumps. I got that all wired up and mocked up where the fuel pump will go. I had to enlarge the original hole I made for the larger diameter wiring plus the fuel pressure sensor wiring from the Vaporworx module.
I know some people may get upset, but given the level of difficulty to remove the fuel tank to service the fuel pump, I decide to cut an access hole for the fuel pump. I'll now be able to service the pump from the top side which will be significantly easier than pulling the rear end in order to drop the tank. I'm going to create a custom recessed panel that will cover the hole and seal it off from the exhaust. I need to paint the tank straps before the rear goes in. That's been bugging me.
The tank is now bolted down again and the new shock bar is installed as well. It makes for a nice piece to secure the fuel pump wiring and fuel line.
Next up is to finalize the rear brake lines on the new rear end. Everything is mocked up and looked great, so it was time to make the lines to connect from the Tee to each caliper. I used 3/16" NiCopp lines which is what I used for the rest of the car. I made this straightener a long time ago out of some screen door rollers and some angle iron. Works great to straighten a roll.
Always love to get an opportunity to use my Mastercool flare tool. Does a wonderful job on the NiCopp lines and the flares are very repeatable. Love having the right tool for the job.
Final results look pretty great to me.
After the rest of my wiring parts were delivered, I was able to finish up the installation of the fuel pump controller. Since the controller is under the rear seat, I wanted to add some protection to the terminals so that it didn't arc if something metal was pushed under the seat. I do have kids that ride in the car afterall, so I have to plan for everything. I found these on Amazon and they were perfect for this application.
Now that the tank is installed and the wiring is done, I was able to test the new fuel pump. Great news is that the fuel pump fired right up to 58 psi, but the bad news is that the upper fuel pump orings were slightly different for LS3 style injectors than the LS1 style rail that I'm running. Passenger side bank sealed, but the driver's side sprayed out of every injector. Fuel was everywhere... At the time I wasn't sure where it was coming from, so after many choice words, troubleshooting and smelling way too much raw fuel, I went inside for the night. After a little research, I determined that the upper fuel injector orings were the culprit. I had an old set of L92 fuel injectors that fit the LS3 injectors and had a larger diameter. That was the fix, and sealed everything up, but it took about 4 days to air out the garage fully.
I updated the tune file a few weeks ago for the new fuel injectors, flex fuel, and new fuel pump to give the engine the best shot at starting and idling. I finally started the engine again after many months and it was surprisingly pretty close because it ran and idled very similar to last year. It did run on the lean side, but once it hit 160*, it started to add more fuel to the table and hit my target AFR. I love Holley EFI!! It was great hearing the engine again, but I need to clean up the rest of the dash wiring and put the interior back together.
Since the engine is running now, that's a huge relief and now I can focus back on the driveline. While I love the look of the cast iron, the third member is raw and needed paint. Most guys tend to paint them the stock primer red that most 9" came from the factory. I decided to change it up a little and spray the Ford rear end with some Chevy Orange! Just because haha.
I love it!!
While I was in the painting mood, I also quickly painted the black calipers red to match the front. I also painted one of the axles since the flange is also raw, but didn't get a picture.
I didn't get a picture, but the third member is installed with a new LubeLocker gasket and torqued down. Only thing left before I install the rear housing is to paint the gas tank straps and tap the lip of the fuel tank down to clear the housing. Hopefully throughout this week I can get the bearings pressed on the axles, reinstall new drop springs and fully assemble the 9". I also ordered a new conversion 1350/S44(3R) Ujoint, CPP drag link and some new CPP tie rod adjusters which some have come in. Will make time to get those installed as well so that the front end can be completed. Very excited to drive the car after all the changes I've made.
« Reply #349 on: June 09, 2025, 07:44:10 AM »
Since I don't have any prior experience with Ford 9" rear ends, I made a call to quick performance to ask them about the order for the spacers, bearings and locking rings. I called them to confirm since the LS1 rear brake setup is probably not as common as the Ford brakes. The guy I spoke with told me that with my LS1 rear brakes that I didn't need the spacer. Wonderful, because I want to make sure that my brake offset is right so I don't have to do it twice and have to remove the bearing since they are a real PITA to remove in one piece.
Quick comparison of a stock 17 spline 55-57 axle and an aftermarket 35 spline. Huge difference!
After bending the lip back on the gas tank, painting the straps, welding in the bump stop that I removed 2 years ago, welding a tab for the brake hose, fighting with a badly leaking caliper brake hoses... I was finally able to install the rear for good. The leaking brake hoses were 100% my fault. I had them oriented horizontally on the machined surface on the caliper, but the brake hose needed to be 90* our because it had a lip on the bottom that wouldn't allow the hose to sit flush. Once I figured out what I did wrong, I was able to get them to seal up. Very stressful in the moment when brake fluid is gushing out of both calipers!
Tons of clearance!
Now that the rear is installed, I can finally install the rear axles and get the brakes final installed and bled.
Stoked to have it finally installed, but as I found it very difficult to get the nuts installed and tightened down. Like there wasn't really enough room? I'm thinking that I may need a specialty tool or something. I was able to make it work with what I had and got everything fully torqued down and really happy with how it's all fitting together. I pulled the brand new rotors out of the box and immediately notice something's not right. The rotor can't fully seat against the axle flange. After troubleshooting, I determined that it couldn't go any further because it was being hung up by the inner parking brake.
Here's the part I missed...
I went in for the night and made a call to Quick Performance in the morning. After troubleshooting for several minutes the tech figured out that what happened is most people order a single bolt patter for the rear axles and with that style blank they require no spacer, but I ordered a dual pattern which does require the spacer. I was happy to learn what happened and now I know what my fix is, but no I need to do what I was trying to avoid and remove the brand new axle bearing. I have a bearing puller, and bought some long all thread to get the extra reach, but the puller kept slipping off. I was getting quite frustrated at this point. Then I thought one last ditch effort would be to attempt to use my press. By some miracle, I was able to get enough of the lip and pull the bearing off completely unharmed.
I installed the spacer, then pressed it all back together with the locking ring and was able to get it all installed correctly. You can see how much more space there is between the parking brake and flange now. Oh and the little missing spacer haha.
Then I moved onto the driver's side. I thought it was some surface rust or something on the axle, but after I pulled it out there were some gouges in the machined surface. I again called QP and they were extremely apologetic, and quickly sent me out a replacement axle and a swag bag to say sorry for the trouble I had. I'm extremely impressed with the customer service from Quick Performance. Stuff happens, and I will gladly purchase from them again.
I didn't take any pictures, but as soon as the axle came in, I painted the flange quick, pressed the new bearing on with a spacer and added the locking ring. Installed everything and it practically fell together.
I didn't get any installed pictures, but my Billet CPP adjusters came in and I installed the tie rods with new MOOG inners and outers. Now the steering is all back together, and can check that off of the list.
I also buttoned up and reinstalled all of the interior dash, steering column and reinstalled the shifter with linkage. I pulled the column so that I could install the seal and cover for the column without cutting it. Turned out pretty good. I need to trim the carpet back a little bit, but overall glad that's installed. That should significantly reduce the amount of engine heat coming into the cabin.
I also installed the little clip that allows the shifter indicator to work. It was very inaccurate, but I lined it up so that it worked with Drive so at least that is right.
The last thing was swapping out the ujoints so it would work with my 1350 yoke on the rear differential. Once everything was buttoned up, it was time to pull the car out of the garage again. The engine fired right up and ran very well considering I swapped the 36lb injectors for 95lb. There were some corrections that the ECU had to do, but once it learned the table around idle a bit, it smoothed right out. I backed the car out and just let it idle. I checked for leaks and was very happy when I didn't find any. I let the fans cycle and things were going great. I pulled it ahead because I was going to snap a picture with the new lowered stance. All of a sudden I heard a hissing sound and there was a fountain in the engine bay of fuel. Shut it off immediately and backed it into the parking spot outside.
After I cooled off, the next day I determined that when I made the mounts for the fuel rail on my bench, that the injectors weren't fully seated down into the intake. So the rear injector pushed down with the pressure from the fuel rail and it dropped enough for the upper oring to fall out of the seat and break the seal. It was a fairly quick fix. I determined that the new mounts needed to lower the rails by 1/8" and that's all it took. I made 4 new brackets, reinstalled and zero leaks. What a fiasco, but I'm glad it happened in the driveway rather than on the highway! After all of that, here's a picture of the new stance. I love it!!
The plan now is to find a shop that will give my car a proper front end alignment and then drive the dang thing!!
« Reply #350 on: June 09, 2025, 08:06:41 AM »
Looks fantastic!!!!
« Reply #351 on: June 10, 2025, 08:34:45 AM »
Killer progress Ryan!
« Reply #352 on: June 10, 2025, 09:54:56 AM »
Thanks guys! I'm really stoked on for the new upgrades. I gave the car the best alignment that I could in my garage, and now I've got an appointment scheduled this Friday for them to do a proper alignment. Very excited to have found someone who will touch an older car. Harder than I thought to get someone to do it.
« Reply #353 on: June 10, 2025, 02:07:55 PM »
Ryan, some very impressive upgrades. What a difference between the 17 & 35 spline axles. With a turbo powered LS and good traction you will appreciate having a rear end that won't give out on you. Funny when you say it's hard to find someone to do an alignment on an older car. Some of the newer unibody cars that I have worked on only have adjustments for toe and nothing for caster or camber.
« Reply #354 on: June 11, 2025, 05:59:43 AM »
That's because shops don't care about hours billed per sey, or taking the time to do "extra".  They want to get customers in and out as quick as possible.  Its like body shops who only want insurance jobs or collision work they can process through quick and over charge the insurance for.  Ok Rant over
« Reply #355 on: June 11, 2025, 06:17:19 AM »
I was surprised my regular shop that I've been taking all my daily vehicles to wasn't interested. When I called he said they don't have all the old data. I said that I can provide all the specs since I have new control arms. Then he said that they don't have any shims, and I replied that I already bought a kit with all the necessary shims needed for 2-3 cars. Then he just flat out said he's going to have to charge me an hourly rate and that it will likely be very expensive. I guess that was his polite way of saying that they didn't want to do my old clunker haha. I do appreciate that he was upfront and honest that it will likely cost a good amount.
« Reply #356 on: June 11, 2025, 07:01:27 AM »
I had a muffler shop basically do the same thing, just kept making excuses on why they couldn't do it.  Not a shop I used before so I just let it go and moved on.  Must be nice to be able to turn down work
langss
« Reply #357 on: June 11, 2025, 08:42:12 PM »
You nailed right there. No Rant...Just the gods honest truth. Quick And Dirty...In And Out...Next. Out here you have to look long and hard to find a shop that will do anything on an older car. And even when you do, the Shop Rate is so high...its like taking out a loan to buy another car. And don't get me started on trying to get an older car smoged out here.
« Reply #358 on: June 12, 2025, 05:16:28 AM »
Thats why mechanics today aren't really mechanics, they are parts swappers.  Just throw parts at the problem till it's fixed, all on the customers dime of course.
« Reply #359 on: June 23, 2025, 03:05:37 PM »
After calling around to different shops, I found a place fairly local that did alignments on older cars. Even the one restoration shop in town recommended them, so I made an appointment. They were able to get me in on Friday the 13th. Not sure if it's good or bad haha.
Car was in good company, so that made me happy.
One thing that has been terribly annoying ever since I swapped the intake and C6 Throttlebody is a loud whistling sound. I thought originally it may be a vacuum leak, but turns out after doing some research when the LS3 throttlebodies are turned upside down they can whistle badly. The solution is porting the hump that is normally on the top of the intake path. I carefully smoothed out the transition and it definitely helped, but the whistle is still there. I may need to do a full on port job to get rid of all the ridges.
I was working on the car a little bit on father's day and decided it was time to install the lower 1955 Nomad trim on the kick panels. Trouble was the trim studs that bend over were either rusted or missing. I made some new tabs and then turned my tig welder way down and was able to fix both sides.
I polished up the original waffle panels and then installed on my new kick panels. My father-in-law gave his light blue panels to me a few years ago and I used SEM vinyl dye to change them to black. Just haven't taken the time to fix and assemble them until now.
I need to clean and paint the original grills, but then they can be installed for good.
I also wanted to get the hole covered back up that I made to access the fuel pump. I bought a flange tool to create a lip, made a cover out of some thicker aluminum sheets I had, and then bent/trimmed it to fit in the recess. Came out nicely and I opted to attach it with seam sealer rather than bolting it together.
I didn't take a picture, but I also used my router and cut out the space above the fuel pump so it wasn't putting pressure on it. I want to put to glue the carpet down on the cargo floor and the rear seats so it will be much more complete. I also think I need to glue some of the carpet down in the passenger area since it slides around quite a bit.
I took the kids to summer camp today that was at the school and got a great picture of it. Love the new stance! I do think that the springs have settled a bit though since my alignment because it seems to be darty and has a fair amount of bump steer now. I'm going to put a few hundred miles on it and see if things get better/worse. Overall I'm stoked with all the upgrades from this winter and now she's getting some miles on her.
Next up is a new pair of front tires. I'm thinking that may have something to do with the steering feeling darty too.
