Author Topic: 1978 Y88 Restoration....Getting ready for bodywork and paint  (Read 251198 times)
Re: 1978 Y88 Restoration....Exhaust
« Reply #240 on: November 26, 2024, 08:55:00 AM »
That looks like a mirror of mine, bundles of wires and gauges hanging on zip ties.
I inquired about if the carb shop had had a chance to look at my Quadrajet, now claiming late January before they even look at it. Bad luck if it was your daily driver, if there were others doing this work their service and attitude would certainly be different.
With all your knowledge and skills I'm surprised you didn't rebuild it.  Is time and space playing a factor in having someone else do it?
Re: 1978 Y88 Restoration....Won't crank over.
« Reply #241 on: December 17, 2024, 01:48:56 PM »
Got the battery hooked up.....I thought I had all necessary wiring connected.  No Start.  Won't even crank over.
I have 12v to the starter.
I know I'm missing something.....Connection somewhere......The clock isn't running so that tells me I missed a connection or two or three.
Any ideas?
« Reply #242 on: December 17, 2024, 05:20:20 PM »
Brain Fart #1
Found the main problem.
Forgot to connect the battery to the alternator.
Got power to the ignition.
The new issue is.....when I turn the key to start it......it clicks at this unit.
What is it and could this be the issue why it won't turn over?
« Last Edit: January 10, 2025, 12:13:28 PM by wheels78ta »
Re: 1978 Y88 Restoration....Engines cranks but no spark.
« Reply #243 on: December 17, 2024, 05:37:24 PM »
Brain fart #2
I put a jumper on the neutral safety switch and now it turns over.
But......it feels like it's not getting spark.
I'll test all the HEI components and go from there.
More to come.
« Last Edit: December 17, 2024, 06:35:50 PM by wheels78ta »
Re: 1978 Y88 Restoration....Engine break in complete.
« Reply #244 on: January 10, 2025, 11:50:27 AM »
Brain Fart #3
I thought it was odd that the rotor turned freely.  So I removed the distributor to find out that when I rebuilt it......I put the distributor gear upside down.  It was sitting below the cam and wasn't, thankfully, touching the cam gear at all.  Once I got that corrected the engine had spark.
« Reply #245 on: January 10, 2025, 11:56:24 AM »
Brain Fart #4
Now that I have spark.....no fuel to the carb.  So I disconnected the fuel line at the point that it goes to the metal line....just behind rear of front tire.....and blew towards the tank.  Plugged.  With cap removed.  Could not get the line to clear.  I went to the tank to remove the fuel line at the side of the tank.
No rubber fuel line.  And I had it capped to keep debris from entering after the install.  Removed the cap on the line, added the rubber fuel line.....now the line is clear from the front of the car to the tank.  Blew into the line and you can hear the gurgling in the tank.  Done.
« Reply #246 on: January 10, 2025, 12:12:39 PM »
Brain Fart #5
After correcting the fuel line issue.......there was still no fuel to the carb.  Pump maybe?
So I disconnected the line behind the rear of the front tire.....added a piece of fuel hose that was sitting on a shelf with other parts stuff.....and stuck the hose into a full can of gas.  Cranked but still no fuel to carb.  So I replaced the pump with another one that I had on the shelf.....still no fuel to carb.  I took the first pump that I removed and tested it on the bench and it pumped fuel.
My head was spinning and I was losing it fast.  What could be the issue?
Then I thought.......is the new piece of fuel hose plugged?  Are you kidding me?  It was plugged.  It wouldn't pull gas from the gas can.  It turned out to be a carpenter wasp nest was about 6" inside the hose from sitting on the parts shelf.
So I put the original piece of hose on and connected the lines together.  Filled the carb with fuel....cranked it over a couple of times..................And she fired right up.
A couple of days later.......I went through the break in procedure.  20-30 minutes of 2200-2500 rpms.  I kept it around 2400 for the most part and went 29 1/2 minutes.  My leg was getting cramped and my foot was going to sleep.  Probably from sitting on a 5 gallon bucket while doing this.  It never overheated....I used a digital infrared thermometer gun while going through the break in plus keeping an eye on the temp gauge.  No leaks any where.  Break in complete.  Oil and filter changed.
And a nice beer break afterwards.
« Reply #247 on: January 14, 2025, 10:41:17 AM »
Congrats!!!
« Reply #248 on: January 14, 2025, 02:44:09 PM »
Thanks, Dave....It was a big relief when the break in went so well.
Now for the fun/hard part............Body work.
« Reply #249 on: January 14, 2025, 03:12:03 PM »
Congrats on the run in. I know exactly how you feel. I didnt think I was ever going to hear my motor running. Such a great sound!
« Reply #250 on: January 15, 2025, 09:27:05 AM »
Thanks......It was pretty quiet for 2400-2500 rpm.  I have the Turbo Pros on it now but I bought the Race Pros to replace them with.  After it's all tuned up I'll get that done before any body work.
« Reply #251 on: January 15, 2025, 11:55:13 AM »
Congratulations your car is alive with a beating heart!
Through the years I have replaced a fair number of flat tapper cam and usually went through a twenty minute break in period. I always wondered how the auto manufacturers got around this break in period?
Re: 1978 Y88 Restoration....Found the final piece of the puzzle
« Reply #252 on: June 17, 2025, 03:32:35 PM »
I bought the NOS Y88 Gold tinted t-top Drivers side on ebay.  I bought the NOS passenger side about 14 years ago.  Now I have all the parts I've been looking for to complete the rebuild.
I need to start on the bodywork but I'm going to put the NOS glass in frames first.
« Reply #253 on: June 18, 2025, 05:26:04 AM »
Wow those look awesome
« Reply #254 on: June 21, 2025, 02:23:48 PM »
Thanks, Dave.
I'll keep them in my searches just to see how much they sell for.  I'd also like to see a set of NOS Silver Mirrored t-tops and their sell price.  Those are also hard to find.
« Reply #255 on: June 23, 2025, 07:25:53 AM »
Thanks, Dave.
I imagine as they are a very low production item
Re: 1978 Y88 Restoration....Getting ready for bodywork and paint
« Reply #256 on: September 30, 2025, 02:54:32 PM »
With the cooler weather setting in I'm wanting to start on the bodywork.  But......................................................
Our IRA investments are paying off pretty good so I'm talking with a professional body guy that wants to take on the project.  He'll get it done quicker than I will so we'll see what his time frame is.
He has over 20 years experience at a body shop and has opened up his own side business.  He has 40 acres and a very nice shop.  Plus he loves doing classics.
As soon as we get a date in the books I'll post the information.  If it works out I'll get pics of the process.
Stay tuned.   :D
