TAC Central > Lobby
Canadian Pontiac Parts
roadking77:
Yes, I knew there was no canadian version of the firebird, I did find that there were only a few models that were badged as 'Acadians'. Maybe I will get lucky findy some decent nos stuff. Unfortunately I wont know for a couple of months.
aussieta:
roadking77 if you see any export 77 tail lights with the amber turn signals i want a pair
wallington white writing and numbers up to 100 km/h, after 100 numbers and tick marks in red
edit after 100 numbers are still white, up to 200km/h, just tick marks are red over 100km/h
roadking77:
Will do, I will be working on a list as I am sure I cannot afford the whole lot.
Wallington:
AussieTA - I should have asked prior, is your Canadian KM/H speedo a 2-window or 3-window version at the bottom? I had (maybe still do) a 3-window version from an 80-81 here once, extra light was for choke. I can't recall if they are easily swapped into earlier clusters with the same circuit board, whereas the tacho types can't. I couldn't see a part number in the listing that mentioned the Canadian option, it may have been there but wasn't clear. Or they may have been in separate specialist listing like export model parts were.
Speaking of export, are you referring to the Japanese amber lens versions? There's a guy in Sydney that supplies the amber ends if you haven't seen them listed, need to graft onto existing and rewire harness though. A few times I'd asked owners of the Japanese models how their wiring layout was, but as usual, no response. I know it wasn't easy to convert the stock setup unless you had an extra few trunk harnesses as spares. It's not as simple as swapping wires or bulb holders, half only fit in one location, others only have one terminal in a twin-terminal socket and if you you try to swap you'll end up with the dim side of the brake light bulb. Not sure how others do them, many are vague, seemingly purchased that way or had someone else do the job, which could be a can of worms if they'd actually check closer.
aussieta:
i have modded my tail lights and wiring harness
i am still not sure if export lights exist or someone bs for rego
my speedo is 1981, in 1980 housing with 1980 circuit board,
only has one window under KM/H, i think
[#] Next page
[*] Previous page
