Author Topic: door windows scrape and whine when opened  (Read 16006 times)
77 Pontiac
« on: August 13, 2024, 02:39:24 AM »
Hi all,
My 77 Formula has power windows, when I roll the window down it makes a horrible whining noise and I have also noticed a long scratch-line on the glass near the front of the window.
I am guessing that there is some steel to glass contact inside my door, but before I rip i apart is there some feltpads or anything that is the likely cause?
Re: door windows scrape and whine when opened
« Reply #1 on: August 13, 2024, 06:27:36 AM »
Likely the guides with worn or missing felt
https://images.app.goo.gl/j66Dt7qniVNUYueo6
I’ve seen replacement felt kits but from what I’ve read a lot, if not all, are basically the loop side of hook and loop (Velcro) strips with the Velcro being much cheaper to source and cut to fit.
« Reply #2 on: August 13, 2024, 07:43:00 AM »
Ya, 3 guide blocks behind door trip top. Later years usually had felt on 2 of the 3, early used all. You can basically match the scrapes to where it's touching, and no, you can't polish glass to remove a scratch like that. There's also fuzzy guides on the front track just below where the mirrors mount, that tension the glass when fully up.
Depending on costs, you can replace the felt with your own stock or get a complete set of new blocks which have been available a few years now. These are basically the same as original so already know they won't last long term!
I had a write-up years ago with what I did but must have been pre-crash. Here's a few of the pics just for ideas. Back then there were none reproduced, and now that they are they aren't cheap either.
I had my original guide blocks replated, I bought some thicker felt from Germany and wrapped it right around on itself with contact glue. I'd tried even thicker in the past but had limited adjustment room. Shows the thickness compared to the repro felt that was available at the time for repairs, likely same as what is used in the new sets.
Window guide repro vs 3mm felt 2 by Ben, on Flickr
Restored replated door glass guides felts 2 by Ben, on Flickr
Restored replated door glass guides felts 1 18x3mm by Ben, on Flickr
This is the extra-thick woollen felt wadding I tried first on the guide blocks above, it later came in handy for replacing the completely worn off fuzz of the window track tensioning guides. I did a post on these as well, gone also. These are originally riveted on, the glass just touches the point. So I did the same but used tiny bolts and locknuts that are clear of the glass. Until recently these tracks weren't available new again either, but again, they likely just have the fuzz that wears off easily.  I also made the pads twice as wide for extra support, less vibrations. These are nearly all that support the glass when the window is up, other than bolted along the rail and limited pressure the door guides and seals provide when door is open.
Firebird replated window tracks with felt guides (2) by Ben, on Flickr
« Last Edit: August 13, 2024, 07:46:56 AM by Wallington »
77 Pontiac
« Reply #3 on: August 13, 2024, 07:46:10 AM »
Thank you, so that begs the question is self adhesive velcro strong enough or do people prefer to use contact spray adhesive instead?
77 Pontiac
« Reply #4 on: August 13, 2024, 07:53:00 AM »
Thank you for that detailed answer, I am located close to Germany, so if you can remember where you got it from I will use the same supplier for sure - It seems like the repo ones are way overpriced and since I have to pay import taxes and overseas shipping I will just re-trim the ones on the car :)
« Reply #5 on: August 13, 2024, 08:08:46 AM »
Haha you use what you have access to and think will do the job. Back then you could buy rolls of the fuzzy strip similar to stock, I wasn't impressed and knew it already wore out and scratched glass so wanted something better.
Stock used this long fuzzy bristle type, but once it worn patches and the hard base adhesive would scratch. This is a NOS GM piece, not the repro. Pics will show if they use something similar. The repro strip years ago was similar, but shorter.
GM NOS window felt guide block 9615760 (2) by Ben, on Flickr
As it turns out the felt was just from ebay, I just remember it came from Germany, not planned that way. I also added a link in the post at the time, a few guys were keen, long gone now. Back then ebay wasn't flooded with often cheaply priced and cheap quality items from China. That's all I was trying to avoid when buying the felt, good quality vs from China.
Although this is an Australian-link, this could be very similar. Seems to be a German felt specialist, which is what it was. I also just remembered that I used contact glue on the white felt on the first attempt that failed, this one has adhesive-backing and very strong. I've also used it for guides on auto shifter assembly. But anyway, whatever works for you, these are just ideas.
You'll have to measure the opening in the block, I used the widest I could fit there which was 30mm.
https://www.ebay.com.au/itm/234828141742?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=pn9zeXdeRku&sssrc=2047675&ssuid=&widget_ver=artemis&media=COPY
« Last Edit: August 14, 2024, 01:04:56 AM by Wallington »
« Reply #7 on: August 14, 2024, 10:18:34 AM »
I checked mine today while there, 30 x 3mm felt on the guide blocks.
20240814_170059 by Ben, on Flickr
And original GM used fuzzy guide near the mirror mount. These will all be swapped out one day for my new glass and restored mechanism and track set with new felts shown in previous pics.
20240814_170127 by Ben, on Flickr
« Reply #8 on: September 24, 2024, 06:57:41 AM »
Did you have a chance to try some new guides or material yet?
TA301
« Reply #9 on: July 22, 2026, 12:43:30 PM »
I am going to refinish the guides soon. I will post results/findings
TA301
« Reply #10 on: July 23, 2026, 11:05:28 AM »
Will the softer, readily available felt work?
« Reply #11 on: July 23, 2026, 10:54:02 PM »
Mine aren't up and running in a driving car so no real feedback of issues. I think you need a little of both. Soft in that it doesn't scratch or scuff, but not so soft that you need to compress too much to support glass and then create a heavy drag effect. Be wary of the felt components for cheaper products, can imagine some using glass fibres, and who knows what else that over time actually scratch.
TA301
« Reply #12 on: July 24, 2026, 04:24:52 PM »
I will use soft felt, two layers and use the adjustability function to see if it works.
TA301
« Reply #13 on: September 20, 2026, 09:50:39 AM »
I have completed replacing both door windows and while at it re-felt the front guide/track as well as the door panel hangers/window rests. I will take a couple of pictures and post.
