Author Topic: Stupid Question  (Read 129 times)
Stupid Question
« on: May 12, 2025, 11:58:55 AM »
Do all Pontiac 400s hold 6 quarts of oil?  Seems like it sits at full at 5 but my dipstick isn't stock.  Better to check cold that hot or vise versa?
« Last Edit: May 12, 2025, 12:01:13 PM by N PRGRES »
Zach
Re: Stupid Question
« Reply #1 on: May 12, 2025, 05:46:34 PM »
Depends on the pan I guess. I normally run the car for a few minutes or so before draining, not enough to make it scalding hot. Think I do about 6 quarts every time.
Re: Stupid Question
« Reply #2 on: May 13, 2025, 07:40:39 AM »
Mine is 6 quarts when I do an oil change.
79GoldnTan
Re: Stupid Question
« Reply #3 on: May 13, 2025, 05:41:51 PM »
Yea, 6 quarts with the filter sounds right
79 solar gold
461.   Factory 4 speed
PTFB SFC
PTFB 1LE
3.08 rear  for now
Lots O Fun
Re: Stupid Question
« Reply #4 on: May 14, 2025, 05:45:22 AM »
I guess my question derives from the fact my dipstick (not talking about myself here) isn't stock and I am wondering if its reading correctly.  I guess I should just dump in the 6th quart and be done with it.
Re: Stupid Question
71455formula
Re: Stupid Question
« Reply #5 on: May 14, 2025, 11:06:01 AM »
If it's not the stock dipstick; you can put 5qts in and see where it is on the markings. Then add to its at the proper level and keep track of how much you put in. With a stock pan it's usually 6qts with an oil/oil filter change.
Re: Stupid Question
« Reply #6 on: May 18, 2025, 02:04:49 PM »
I had an issue decades ago with a foreign dipstick, and scribed a line on it, after an oil change. (6 quarts, W/filter).
Re: Stupid Question
« Reply #7 on: May 18, 2025, 04:23:36 PM »
The dipstick for my 79 motor was lost. So I sourced an 'original' from someplace. Before I got a chance to use it I found the original. The replacement one was about an inch or so shorter than the original. I cant imagine what that would have done to the levels :shock:
Re: Stupid Question
