Sorry for my delayed post - house projects seemed to have taken over for the last few weeks but work continues!!
TA Turbo - thanks for the reply, I will definitely PM you for more info.
Progress Update - I''ve been collecting parts and cleaning the block and removing carbon from pistons (before and after pics below). I know thats not necessary but figured why not. Planning to paint it Pontiac Blue this weekend. Also received the heads from the machine shop and wow, they look great but were $200 more than I anticipated. Only material purchases in last few weeks are Speed Engineering Headers, a TBSS intake with throttle body, fuel rails, and injectors, ICT Billet brackets (planning to use truck accessories for the most part), and Shiftworks conversion bracket.
Next big purchase will be the Holley Terminator X Max then need to figure out what mounting hardware I will use. Leaning towards Holley but still TBD...
Parts List Update
$2,300 - 6.0L LQ4 with 4L80e from 2003 Chevy Express 3500 (delivered to my house)
$0 - 853 Heads
$450 - Machine work for the heads including 3 angle valve job
$29.99 - Timing Chain (Summit; SME-143012)
$59.98 - Timing Chain Dampner Kit (Summit; TFS-K30675600)
$491.61 - Truck Norris Camshaft Kit (BTR; Cam, Stock LS Pushrods, 0.560 Beehive Valve Springs, Valve Seals
$160.95 - Trunnion Kit (Summit; Comp Cams CCA-13702-KIT)
$14.99 - Cam Retainer Plates (Summit; SUM-150106)
$29.98 - Valve Cover gaskets (Summit; Brian Tooley Racing BTC-BTR37683)
$20.75 - Timing Cover Gasket (Summit; Brian Tooley Racing BTC-BTR33904)
$19.99 - Timing Cover Seal (Summit; Brian Tooley Racing BTC-BTR85673)
$6.99 - Harmonic Balancer Botls (Summit; NAL-12557840)
$71.78 - Head Gaskets (Rock Auto; GM 12589227)
$36.98 - Head Bolts (Rock Auto; Fel Pro ES72173)
$67.96 - Oil Pump (Amazon; Melling M295)
$35.40 - Cam Sensor (Amazon; Standard PC273)
$44.79 - Crankshaft Sensor (Rock Auto; AC Delco 213-354)
$33.46 - Ignition Coil - only one was bad (Amazon; Delphi GN10119)
$11.00 - Coolant Temp Sensor (Amazon; AC Delco 213-4514)
$27.79 - Oil Pan gasket (Rock Auto; GM 12612350)
$178.95 - Delphi LS7 Lifters and Guides (LSXceleration; 25341990K1)
$215.45 - 98-02 F Body Oil Pan Kit with pan, gasket, windage, dipstick, tube, etc (Parts Geek; 103-071KT)
$195.00 - TBSS Intake with throttle body, rails, and injectors (Facebook Marketplace)
$165.00 - ICT Billet Alternator / Power Steering Pump Brackets (Amazon; ICT Billet 551519X-3)
$338.97 - Speed Engineering Long Tube Headers with bolts and gaskets (Speed Engineering; 25-1025-1)
$105.99 - Shiftworks Shifter Conversion (Summit Racing; SC2262)
![](https://i.imgur.com/mS9EB48.jpg)
![](https://i.imgur.com/Jg0jv3O.jpg)
![](https://i.imgur.com/b3LK5x9.jpg)
![](https://i.imgur.com/gXCK77S.jpg)
![](https://i.imgur.com/cA5Woym.jpg)
![](https://i.imgur.com/4vqSeaW.jpg)
