For all Firebird - Trans Am Enthusiasts
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Mechanical
key still not turning
« previous
next »
Pages: [
1
Author
Topic: key still not turning (Read 941 times)
Mileswinger
1977 trans am 403
on:
November 20, 2021, 12:23:54 AM »
So my key isn't turning an the first thing i thought it would be is the ignition cylinder so I replaced it and it still doesn't work so Then I thought my transmission has been acting up maybe its the lever on the steering column so I detached the rod from the linkage below and just rotated my collar on the steering Colum all the way to the right to manually put the lever in park and still nothing is there any other reason why my key wont turn? I'm pretty clueless now any help would be greatly appreciated
1977 trans am 403
Re: key still not turning
Reply #1 on:
November 20, 2021, 04:35:50 AM »
How did you swap out an ignition barrel and adjust switch if still locked up somewhere? Have you had the car jacked up or parked against blocks or similar prior to the issue? Steering wheel swap prior? Trying to rule out issues where the steering lock comes into play and also stops key from being able to move.
Reply #2 on:
November 20, 2021, 05:57:34 AM »
If by “all the way to the right” you mean you rotated it clockwise as facing it from the drivers seat that is not park. The opposite, fully counterclockwise, would be “park”. Just FYI
Reply #3 on:
November 20, 2021, 07:31:35 AM »
Good info also. Mine doesn't use that setup so can't comment.
Mileswinger
1977 trans am 403
Reply #4 on:
November 20, 2021, 03:48:56 PM »
I just pulled apart the steering column to replace the barrel I do have a after market grant steering wheel but I don’t think that would be a problem where else can I look to find where it’s locked up
1977 trans am 403
Reply #4 on:
aussieta
Reply #5 on:
November 20, 2021, 09:12:18 PM »
i assume you have the correct key
and the key and barrel are not too badly worn
1978 Y84 W72 WS6
Mileswinger
1977 trans am 403
Reply #6 on:
November 21, 2021, 02:16:01 AM »
Ya new barrel and keys
1977 trans am 403
aussieta
Reply #7 on:
November 21, 2021, 03:34:55 AM »
new barrel and keys
are they actually coded, "repinned"
1978 Y84 W72 WS6
nUcLeArEnVoY
Reply #8 on:
November 24, 2021, 02:37:17 PM »
Did you check the wheel in the sky? That usually turns.
Reply #8 on:
Pages: [
1
« previous
next »
TAC Tech
Mechanical
