TAC Tech => Interior => Topic started by: roadking77 on February 08, 2021, 07:38:56 AM
Recently re-did my steering column. Tilt was nice and tight so all it needed was a cosmetic refresh. Take the switches apart clean good with contact cleaner and hope for the best. Collar was stripped then re-coated with VHT wrinkle paint.
(https://live.staticflickr.com/65535/50912534908_6a2a467d62_b.jpg) (https://flic.kr/p/2kyY3S1)2021-02-05_07-52-15 (https://flic.kr/p/2kyY3S1) by Kerry Grubb (https://www.flickr.com/photos/156399515@N07/), on Flickr
(https://live.staticflickr.com/65535/50912841197_c8b6371cf6_b.jpg) (https://flic.kr/p/2kyZBUR)2021-02-05_04-19-53 (https://flic.kr/p/2kyZBUR) by Kerry Grubb (https://www.flickr.com/photos/156399515@N07/), on Flickr
(https://live.staticflickr.com/65535/50891577782_3aa677c8a3_b.jpg) (https://flic.kr/p/2kx7D3f)2021-01-30_01-21-26 (https://flic.kr/p/2kx7D3f) by Kerry Grubb (https://www.flickr.com/photos/156399515@N07/), on Flickr
(https://live.staticflickr.com/65535/50891461316_e8450363b4_b.jpg) (https://flic.kr/p/2kx73qd)2021-01-30_01-21-38 (https://flic.kr/p/2kx73qd) by Kerry Grubb (https://www.flickr.com/photos/156399515@N07/), on Flickr
(https://live.staticflickr.com/65535/50891416028_77aa14bbd5_b.jpg) (https://flic.kr/p/2kx6NXo)2021-01-30_05-11-23 (https://flic.kr/p/2kx6NXo) by Kerry Grubb (https://www.flickr.com/photos/156399515@N07/), on Flickr
Beautiful work.
Thank You. I expanded a bit in my resto thread, but I will add here. I put a coat of SEM colour on the collar, it 'melted' off the wrinkle paint! So I did that part twice. Second time around I put a coat of primer on first. Then the SEM. That did the job but with the additional layers of paint the texture was a bit obscured. SO, I think a third go round may be in the works. Also waiting on a new key switch before I get the collar re-installed.
Great work Kerry but it might make sense to double check the wiring and maybe get a new neutral safety switch.
Wiring on the column is fine, but I think you may be right Jack, those parts arent that expensive. I did all new on the 77, figured a good cleaning might do the trick with these.
I may have to replace my steering column on my 73 TA, just to get one with tilt.
I've looked at the Flaming River option for $1K, is there any other place to purchase
a reman column?
Thanks,
Darryl
PM sent
Kerry,
I didn't see it. Resend to DLRegister@reagan.com
Thanks,
Darryl
Darryl, Ames had reman. units in their catalog, not sure of the availability. Craigslist maybe. I know a guy that may have one but not sure.
I tried your email but it kicked back undeliverable :shock:
If you get a chance send me an email
morgandane@zoominternet.net
Kerry,
I decided to go with the Ididit steering column and a DSE steering wheel and adapter.
Thanks for the help,
Darryl
Looks great!
