Author Topic: Cooling question  (Read 448 times)
formula46two
Cooling question
« on: August 01, 2023, 06:47:21 PM »
I have a aluminum radiator and wondering what coolant to use on 78 400.
Still a 50/50 mix?
Also will the air cleaner/shaker setup work on a Edelbrock carb?
Re: Cooling question
« Reply #1 on: August 01, 2023, 08:54:05 PM »
Do you have an air cleaner at present to test? Need to check height but also linkage clearance. Any carb spacers? Stock intake or height?
« Reply #2 on: August 02, 2023, 11:59:30 AM »
If it was mine I would use "typical" green antifreeze.  The traditional green stuff is "inorganic acid technology."  I'm sure that some of the newer "all makes and models" antifreeze would be okay, but I don't really know.  Our cars have a copper brass heater core.
« Reply #3 on: August 04, 2023, 01:48:29 PM »
Any traditional green antifreeze that adheres to GM 1899M standards, as specified in your service and owner's manual. 50/50 mix of concentrate and distilled water.
Zerex Original Green is a good one a lot of folks use.
They sell it pre-mixed 50/50 as well. A six gallon case is available on Amazon for a pretty cheap price (around $80), which is plenty for our entire cooling system.
You can use the Prestone stuff in the yellow jug in a pinch since they sell it everywhere, but it's not the correct color or formulation to use as standalone coolant for our cars - that stuff is meant to be more of a universal coolant that will mix with any other kind for top-offs.
formula46two
« Reply #4 on: August 04, 2023, 05:03:39 PM »
Yes I have the original cleaner , I suppose if it fits over the Edelbrock it will work
formula46two
« Reply #5 on: August 04, 2023, 05:05:15 PM »
Yes I will go with this one. Getting exhaust system installed and so close to the fire up
Zach
« Reply #6 on: August 05, 2023, 11:02:17 AM »
My loop is already super dirty. New big 3 row radiator from a Camaro, and whatever the cheapest antifreeze there is. Works for me haven’t seen any issues, never goes above 180 no matter the temp or load.
