Author Topic: My Tenth Anniv.  (Read 45143 times)
« Reply #480 on: April 12, 2024, 06:40:17 AM »
Wow, you do such a nice job on your restorations! Everything looks fantastic, keep up the good work.
« Reply #481 on: April 12, 2024, 07:25:49 AM »
Looks great! I wonder which is better? I really don't know. I found a copper one from somewhere as I was afraid to try the aluminum. The copper one was in the car so that's what I put back (as I didn't want to have to do it aging on my lifetime). They make aluminum radiators so they have to be good, right? This is purely a thought I ponder not a bash on you putting in an aluminum unit.
« Reply #482 on: April 12, 2024, 08:08:12 AM »
Heater box looks better than new. One less thing to worry about!
Regarding what material is better or best, I don’t know! I actually thought they used to use copper tubes and brass fins. I do know all modern high efficiency radiators are made of aluminum. I have heard it could be cost factor but also that long life antifreeze doesn’t like copper. Forever AC evaporators and condenser coils have been made out of aluminum.
sreta
« Reply #483 on: April 12, 2024, 09:07:46 AM »
I don't know about aftermarket unit, but original heater core has copper core and the rest is brass.
« Reply #484 on: April 12, 2024, 12:30:09 PM »
The one I took out was copper. In all fairness I think the $130 part from Ames is said to be copper. My car doesnt get that much use in the winter so honestly I could care less if the heat is efficient or not. It doesnt even work in my black car and I have gotten along just fine. I had the same thought regarding the fact that radiators are aluminum but then I wondered is that because there is more heat loss to make it more effective! Not what you would really want for a heater core. In the end, its still the same hot water flowing through, with the air moving across the fins so I cant see it making any difference. No one will ever be seeing it so Im not afraid to loose a point in judging :grin:
« Reply #485 on: April 29, 2024, 06:10:43 AM »
20240425_141626 by Kerry Grubb, on Flickr
Under dash duct had a hole in it patched up with duct tape. I had a few free minutes so I figured I would try to fix rather than get a new one (I looked on Franks website and they have nothing currently). I thought I had a full set of duct work but after a search around the shop I came up empty. Fortunately the pieces broke off fell inside the part so I was able to patch it back together and then I fibreglassed over. It was kind of messy, so I followed up with some flex filler, then fillable primer from Rustoleum, then some rustoleum satin black. I then used SEM clear satin on top. I was surprised the SEM didnt react with the Rustoleum. Its not perfect but once its tucked up under the dash I think it will be fine.
20240427_121156 by Kerry Grubb, on Flickr20240427_140929 by Kerry Grubb, on Flickr20240427_140929 by Kerry Grubb, on Flickr20240428_173138 by Kerry Grubb, on Flickr
« Reply #486 on: April 29, 2024, 06:15:33 AM »
20240427_165641 by Kerry Grubb, on Flickr
Next up is brakes. Bench bled the master, got things hooked up and started with the fronts. No problem. Then it came to the rears :shock: Slight hiccup, once thats figured out I will post my findings.
So in the meantime it was time to take a break
20240428_173714 by Kerry Grubb, on Flickr20240428_172637 by Kerry Grubb, on Flickr
Burn up some sticks from the back yard and cook some smores with the grandson.
« Reply #487 on: April 29, 2024, 06:20:27 AM »
Great work Kerry, keep it up. Love camp fires!
« Reply #488 on: April 29, 2024, 06:24:21 AM »
Lookin good!
« Reply #489 on: April 29, 2024, 07:27:59 AM »
Nice job on the AC duct. It should be good for another 45 years, maybe  more.
81Resto
« Reply #490 on: April 29, 2024, 08:07:35 PM »
Awesome job on the heater duct repair.  The whole project looks to be coming out great!
« Reply #491 on: April 30, 2024, 09:40:41 PM »
Congrats on all the progress.  You're practically finished! ;-)
This TATA is going to be a beaut!  Sounds sweet too.
« Reply #492 on: May 01, 2024, 04:55:12 AM »
I knew after waiting for a gazillion years to have my motor rebuilt I should have named this car 'Patience'. But Im not one of thos that name cars. Now I am reconsidering :shock: Or maybe just PIA
Front brakes all fine. I could not get a vacuum on the back to save my life. After a few unsuccessful tries I decided to check that my fittings were tight. I DID NOT HAVE THE MAIN LINE HOOKED UP TO THE SPLITTER AT THE REAR END :shock: :sad: :mad:
So, hook that up and still no vac. Trip 2 lets look at the fittings again. The line input to the caliper was nice and tight, however the line moved freely in and out of the caliper, like it was missing a stop/washer ferule or something? With some advice and looking around I could not figure how to remedy the situation without a complete hodge podge. I called FbirdCentral where I bought the calipers (years ago now) and found they are for someone doing a disc brake swap onto a drum car. The fitting is accomplished with a banjo bolt and flex line much like the fronts. Rather than going through a bunch to make things jive, I found a set of rebuilt original calipers and placed an order. Hope they work!
« Reply #493 on: May 07, 2024, 01:38:29 PM »
Rear Brake saga continues. I got a set of 'rebuilt' calipers (not cheap) but they are basically the same thing as I bought from firebird central. They are NOT originals rebuilt but a replacement. I still have the same problem, getting the line attached to the caliper itself. After getting some pictures in another thread from a kind member here I can finally see the problem. There is as described in the service manual a 'block' that attaches to the caliper with a banjo bolt that the brake line threads into. THIS is the part I am missing. SO, I started to think about it and I can vividly remember tearing my original caliper apart and refinishing it, I even bought a rebuild kit. I found the rebuild kit but no idea where the caliper is after an exhaustive search. I figure, 'hey, I might have made a post about rebuilding the caliper  :???:'. I went back to page one of this thread and BAZINGA, right there on page 2, dated June 16, 2021 is pictures of the rear caliper before and after a cleanup. NOW ALL I HAVE TO DO IS TEAR MY SHOP APART TO FIND IT. I never throw any car part away, I cant imagine I would have gotten rid of this.
« Reply #494 on: May 08, 2024, 04:56:57 AM »
20240507_174435 by Kerry Grubb, on Flickr
After digging through every box I had in the shop, and thats a lot :shock: I had given up. I knew I did not throw them away but got to the point that there was nowhere else I would have put them. THEN, I saw my flare kit peeking out on the corner of the shelf. I wondered, is there a chance................?  I have looked over that spot multiple times during my search as I KNEW the only thing there was my plumbing and electrical tool kits. However with all other spots coming up empty and nothing to loose there IT WAS :grin:
Got the block off, and of course the fitting on my brake line was not compatible. Luckily I had one in my pile of parts, got the flare kit out and new end put on. Got everything hooked back up on the car, gave the bleeder a few minutes of pumping with my vac tool but wore my hand out (minor case of arthritis) so I will get some help today to do some pushing on the brake pedal. Hopefully that will be quicker and easier.
20240507_174657 by Kerry Grubb, on Flickr20240507_182012 by Kerry Grubb, on Flickr20240507_182059 by Kerry Grubb, on Flickr20240507_182203 by Kerry Grubb, on Flickr
« Reply #495 on: May 08, 2024, 06:03:21 AM »
Nicely done Kerry, I knew you would find them. In your quest for the calipers did you find anything you weren't looking for? Gold nuggets or a valuable baseball card? It seems whenever I am searching for something, I find everything but what I am looking for.
You are getting close to having a driver. Many years ago, when I was doing my 19975 TA, I slowly drove it up and down the alley without doors, hood or a front clip. All it proved was it could move and stop, but I was excited anyway.
« Reply #496 on: May 08, 2024, 08:21:46 AM »
I did find a lot of stuff I either forgot or didnt know I had. When I bought this car it was literally packed full of boxes of trans am parts. I was joking with my son the other day that I should get a spot at Carlisle and sell it off. I found a lot of fasteners I did not know I had, some of the small parts I will be needing soon as well. I organized a bit, and took the stuff I think I may need and put it in one box. I am not a seller, but I really should do something with all I have. Once the 79 is finished I may do a purge.
As for driving, I have 2 sets of seats (did I mention the car came with a lot of extras :shock:) and I put a black hobnail in there temp. The TATA seats are shredded wheat, not toast. Once I get the brakes straightened out I hope to put the front sheet metal back on. At that point hopefully it will be a short time before I can take a spin around the block. I have all of the interior except the seat covers. For the last couple of years I have been waiting on Legendary to have a sale. Its about to the point that I need to pull the plug and get them ordered. It should be the last big expense to get this car finished. When I did my 77 it was 99% finished before I put it on the road. With this one as soon as I am at a point that I can get it insured I will get the tags.
« Reply #497 on: May 08, 2024, 10:01:40 AM »
I'm glad you're not losing it. Every time I search for something I know I had, I begin to think I'm going crazy and I sold it, gave it to someone or loaned it out. It really messes with my head.
I have the same flare tool, but I haven't used it yet.  I hear they are pretty cool.
« Reply #498 on: May 08, 2024, 03:05:47 PM »
Yes I was beginning to wonder if I had given/sold them to someone. The flare tool works pretty well. This line was stainless so it took a bit more muscle, bends like a breeze with the nicop.
« Reply #499 on: May 10, 2024, 07:58:49 PM »
Got a little more done over the weekend. I had a few loose bolts from the install so I went back and made sure everything was socked down good and tight. I got a new pair of 'correct' battery cables and got those installed.I got a new pair of 'correct' battery cables and got those installed. I was going to get those from napa but they have let me down with parts as of late so I chickened out and spent the big bucks :sad: I think at this point all of the electrical connections are done :? I am getting a grasp on the vacuum crap. Still looking for a few parts for that. Fuel lines hooked up. Refinished the gas pedal and got a new cable installed. Need to place another order for some more parts, probably wont be in until the end of the week. I am planning on going to the AACA convention towards the end of the week so I wont get much accomplished.
The positive battery cable should be the same for 78-79....#8097031.  Is the negative the same for the 78-79?  Do you have a part # for the negative cable?
1987 K5 Blazer---The Crawler
« Reply #500 on: May 11, 2024, 06:29:33 AM »
Let me check on the cables, I will get back to you. I bought them from Firebird Central if that helps. They were about twice the price of NAPA but I wanted to make sure they were correct.
« Reply #501 on: May 11, 2024, 08:08:00 AM »
No hurries....And thanks for checking.
I have a NOS positive cable.
The negative cable from Firebird Central has the # 12000152 FL code.  Just making sure that is the correct one.
