Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Mechanical
Small brake fluid leak between my master cylinder & power brake booster.
« previous
next »
Pages: [
1
Author
Topic: Small brake fluid leak between my master cylinder & power brake booster. (Read 237 times)
NITEBIRD
on:
July 08, 2023, 04:57:02 PM »
I was getting ready to drive my car (1979 TA/SE 4spd) and decided to check my brake fluid since I dont drive the car very often. I noticed that the rear bowl of the master cylinder was very low. I did some more looking around and I noticed that there is a small leak between the master cylinder and power brake booster.
Anybody know what might cause this? Would it be a bad master cylinder or something wrong with the booster.
Approximately 8 years ago I installed a new master cylinder and had the brake booster rebuilt by Booster Dewey.
I know all parts fail at some point but I just want to know if somebody else had something like this happen and what the cause of it was so i can fix it.
Any input is welcome and thanks!
aussieta
Re: Small brake fluid leak between my master cylinder & power brake booster.
Reply #1 on:
July 08, 2023, 08:22:58 PM »
master cylinder leaking
standard booster only ever contains air
hydroboost will contain oil
1978 Y84 W72 WS6
Reply #2 on:
July 08, 2023, 08:54:03 PM »
It's also the cheapest and easiest option to replace.
langss
Reply #3 on:
July 08, 2023, 09:14:54 PM »
I had the same thing on my 86TA... Helps to have a "Bench Vice" to "Bench Bleed", but can be done with a big C clamp on a bench. If your careful, you can switch them without bleeding the whole system. You Just Have To Be Speedy And Have A Helper.
Reply #3 on:
Pages: [
1
« previous
next »
TAC Tech
Mechanical
