Author Topic: Plug wire orientation  (Read 374 times)
formula46two
« on: July 02, 2023, 12:00:05 PM »
Hi all, America!
 I am trying to route the custom made for my application wires and some are not working out the way I am starting #1. Is there a factory known for where they placed the #1 plug wire?
Re: Plug wire orientation
« Reply #1 on: July 02, 2023, 12:36:58 PM »
I believe it would be in the general area of your uncapped terminal. Kind of toward the firewall/driver area
formula46two
« Reply #2 on: July 02, 2023, 01:19:26 PM »
That's what I was thinking. So much for the made to fit wires a couple of them are just too short so I guess I will just put them how they will fit and renumber them.
« Reply #3 on: July 06, 2023, 10:19:23 AM »
Would it help if you re-clocked the distributor?
TA301
« Reply #4 on: July 07, 2023, 03:17:24 PM »
Placement of the #1 wire is correct so long as the BAT and Tach terminal connectors are right below it. All the other wires are correctly placed too. The one without a wire attached [next to #1] is obviously the #8 Looks correct to me. The way you want to route them is the longest to shortest format. Lay all of the wires on a flat surface and organize them from longest to shortest and then start from there. Worked for me like a charm.
« Last Edit: July 07, 2023, 03:20:43 PM by TA301 »
formula46two
« Reply #5 on: July 07, 2023, 07:23:26 PM »
The vendor(performance distributors) is remaking three of them for me so it looks like will work out.
