Howdy all, got a weird starter grind issue. Replaced the original style starter for a mini starter due to heat soak issues. Used to work great and still does although the grind issue is now happening all the time, it used to be rare. The grind I am referring to comes ONLY after the engine has started, as in the small period of time between letting off the key and the engine fully starting. It sounds pretty violent, I took a look at the flywheel and there is clearly something wrong. Somehow the starter is hitting the flywheel on the engine side, there is some obvious marks. Some notable discrepancies are that the starter came with two bolts that are shorter and are needed compared to original bolts (too long), and they are not nurled. All I have tried is shims, I am going to get more as well as maybe some washers so I can use original nurled bolts as well. Just looking for insight, I know minis can be finicky. Thanks.
