Not sure what happened, So as I said I put a ball valve on the heater core line shutting it off. The engine ran fine, temp normal, inside temp down. Now since I did this my distributor failed. Either the stator or module went bad and shut the car down after a hot soak. This occurred twice until it finally would not restart. The distributor was only months old which less than 200 miles on it. Does anyone think blocking the line raised the temp at the rear of the block, heads or manifold causing the failure?
Thanks for the input!
