Author Topic: Window sweeps  (Read 307 times)
Window sweeps
« on: March 13, 2024, 05:15:19 PM »
How do you get to the screws for the exterior sweep?  Pull out the window?
81 Trans Am
Re: Window sweeps
« Reply #1 on: March 13, 2024, 06:04:25 PM »
Opposite. Drop the window. Move the lower stop down or remove, then sink the glass down past it.
Re: Window sweeps
« Reply #2 on: March 14, 2024, 02:44:03 AM »
Thanks. I was looking at it and thought that might be an option also.
81 Trans Am
81Blackbird
Re: Window sweeps
« Reply #3 on: March 14, 2024, 02:51:46 AM »
Are you replacing them with OER sweeps or just cleaning up?
Re: Window sweeps
« Reply #4 on: March 14, 2024, 06:14:10 PM »
Replacing with ones from firebird central
81 Trans Am
Re: Window sweeps
81Blackbird
Re: Window sweeps
« Reply #5 on: March 15, 2024, 04:42:14 AM »
https://www.transamcountry.com/community/index.php?topic=84363.msg11121#msg11121
Wallington started this thread.  I feel it's very helpful.  See reply #2.  Not sure where Firebird Central gets theirs, but I tried 3 different vendors before I
found a set of OEM sweeps.
Re: Window sweeps
« Reply #6 on: March 15, 2024, 05:23:15 AM »
I saw that thread. I’m not sure either but it’s worth a shot.
81 Trans Am
81Blackbird
Re: Window sweeps
« Reply #7 on: March 15, 2024, 05:50:48 AM »
Another member and myself put some relief cuts in the curve to get it to fit.  That worked but the sweep wouldn't sit flat on the glass.
Not sure witch style your getting but this is for the 1/8 SS bead.  Let us know how yours come out.
Re: Window sweeps
« Reply #8 on: March 18, 2024, 06:14:27 AM »
Got these in this weekend from Firebird central.  To me they look pretty spot on with maybe some very minor adjustment
81 Trans Am
Re: Window sweeps
« Reply #9 on: March 18, 2024, 06:36:38 AM »
what brand are they?
Re: Window sweeps
« Reply #10 on: March 18, 2024, 06:56:41 AM »
No idea, i'll have to look at the packaging again.  Or just order from the same place....
81 Trans Am
Re: Window sweeps
« Reply #11 on: March 18, 2024, 06:59:33 PM »
There is nothing on the packaging to indicate who made it.
81 Trans Am
81Blackbird
Re: Window sweeps
« Reply #12 on: March 19, 2024, 02:53:02 AM »
I'm glad you found a place that sells the correct profile.  Be sure the ends are bent in such a way that they don't rub on the door and scratch the paint.
Re: Window sweeps
« Reply #13 on: March 21, 2024, 06:28:29 AM »
I can't open the pics larger here, and in the other program it doesn't even show attached pics at all. Did you get round bead? That is again, a confusing seal to get, many don't mention what type of bead it comes with or automatically list that it suits both models. Many won't care, many do. For what it's worth all 70-81 Firebird came with the round bead, while 70-79 Camaro had the flat bead, switching to round bead for 80-81 for whatever reason. And those with decor trim, just rocking out and doing their own thing with no silly beads at all!
Re: Window sweeps
« Reply #14 on: March 21, 2024, 06:39:30 AM »
I have the round bead.  Firebird Central actually has a nice video on the site explaining the differences between them all and how to verify which ones you have
81 Trans Am
Re: Window sweeps
