TAC Tech => Exterior => Topic started by: chief poncho on December 02, 2021, 02:44:30 PM
Getting ready to reinstall the fuel tank. Any suggestions on the best padding to get for the anti-squeak pads? Looks like a lot of options out there, but few with decent reviews. It's something people won't ever see, but I want something that will last.
I used 30 weight roofing paper folded in half and cut to length and width.
Likewise-no issues.
Thanks for the replies. I thought about using roofing paper since it looks like the same stuff.
When doing my engine upgrade I switched to an EFI ready fuel tank, from "TANKS". I purchased these adhesive rubber insulator strips from them. I used them to insulate between the tank and trunk floor. I did not put anything between the straps and tank because the factor did not.
In my opinion they work well.
https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=413/category_id=128/mode=prod/prd413.htm
I would think 30lb felt would be fine. All you need is a break between the 2 metals. I used a piece of black foam I cut to fit that look similar to the tank pads that were posted. I got a piece of scrap from a vendor at Carlisle that had 500ft rolls of the stuff about 6' wide. I asked if he sold smaller stuff and no dice. He then reached down and ripped a piece off the end and gave it to me.
Likewise, thin neoprene roll here, compresses and doesn't soak up moisture.
