TAC Tech => Mechanical => Topic started by: NITEBIRD on July 08, 2023, 04:57:02 PM
I was getting ready to drive my car (1979 TA/SE 4spd) and decided to check my brake fluid since I dont drive the car very often. I noticed that the rear bowl of the master cylinder was very low. I did some more looking around and I noticed that there is a small leak between the master cylinder and power brake booster.
Anybody know what might cause this? Would it be a bad master cylinder or something wrong with the booster.
Approximately 8 years ago I installed a new master cylinder and had the brake booster rebuilt by Booster Dewey.
I know all parts fail at some point but I just want to know if somebody else had something like this happen and what the cause of it was so i can fix it.
Any input is welcome and thanks!
master cylinder leaking
standard booster only ever contains air
hydroboost will contain oil
It's also the cheapest and easiest option to replace.
I had the same thing on my 86TA... Helps to have a "Bench Vice" to "Bench Bleed", but can be done with a big C clamp on a bench. If your careful, you can switch them without bleeding the whole system. You Just Have To Be Speedy And Have A Helper.
